Small Byrd
Eastwood
Small Byrd
Postby Eastwood » Sat May 02, 2015 4:23 pm
I recently started buying the Spyderco Dragonfly and I'm wondering if Byrd makes one about that same size?
paladin
Re: Small Byrd
Postby paladin » Sat May 02, 2015 6:30 pm
the Robin would be the closest, I think
danospydermano
Re: Small Byrd
Postby danospydermano » Wed May 06, 2015 2:36 am
I have a Robin 2 & like the size. It's my house knife that I keep in my lounging pants. It's probably really close in size to the D-fly. The FRN has a decent grip and I removed the pocket clip because it just don't need it IMO.
If carrying 2-is-1 and One-is-None...What is Five?
araneae
Re: Small Byrd
Postby araneae » Thu May 28, 2015 6:11 pm
Yep, you want a Robin, very close to the D'fly, but a tad heavier with the liners.
-Nick
Just got:Rex 45 Para 3 LTWT, Harrier 2 LTWT
Re: Small Byrd
Postby sal » Thu May 28, 2015 8:09 pm
Hi Eastwood,
Welcome to our forums.
The "Robin" was designed within the parameters that I used to design the "Dragonfly". Also similar to the "Cat". The models serve a size requirement which is challenged by creating enough handle purchase to adequately control the blade. All three models received a great deal of design time and development.
The Dragonfly was originally designed to fit the requests for a knife design between the Endura and the Delica. Probably in the '92 or '93. It was the first design that I did with a finger choil. I got the finger choil idea from Hiroyuki Sakarai who designed for Moki knives at the time. We just upgraded the Dragonfly design recently.
The Robin was also designed with a finger choil in mind and the need to create a design in that size that worked well and could be made by the makers in China. Though I must admit that the new maker that is making the Robin is quite exceptional and they are coming off the line very nice and at a very affordable price (low Yuan). It works well, it's ergonomic, has good control over the blade and the steel has an acceptable .8 carbon with a good heat treat. We're working on a Titanium version. It's a real knife.
The Spyderco Cat is an evolution of the Salsa.
Nasgul
Re: Small Byrd
Postby Nasgul » Mon Aug 03, 2015 12:10 pm
I love those kind of explanations !! It's always interesting !
Thanks Sal ! Even If i was not the one who made the request.
I already had look to the Bird's, may be I'll look again at the Robin and friends.
:spyder: adds color to your knife addiction :D
Donut
Re: Small Byrd
Postby Donut » Mon Aug 03, 2015 12:44 pm
The current Robin is a little larger than the Dragonfly, but it is sort of similar.
I think it has a 4mm thick blade on it, so it's quite a bit wider, the rest might be slightly larger than the Dragonfly.
It's a great model and feels quite a bit heftier than the Dragonfly.
-Brian
A distinguished lurker.
Waiting on a Squeak, Pingo, and Cliptools with a Split Spring!
Nasgul
Re: Small Byrd
Postby Nasgul » Tue Aug 04, 2015 10:07 am
Look like the weight is the "same" if we compare the G10 Robin 2 to the G10 Dragonfly. :)
But if we compare FRN D'Fly to FRN Robin, the Robin nearly weight twice more. :confused:
araneae
Re: Small Byrd
Postby araneae » Tue Aug 04, 2015 5:21 pm
Nasgul wrote:Look like the weight is the "same" if we compare the G10 Robin 2 to the G10 Dragonfly. :)
Robin has steel liners, D'fly has none.
-Nick
Nasgul
Re: Small Byrd
Postby Nasgul » Fri Aug 07, 2015 8:50 am
No ;)
G10 Dragonfly has steel liners.
It's why I made 2 lines to compare.
G10 Dragonfly vs G10 Robin 2
FRN Dragonfly vs FRN Robin
So if I had to choose I'll take the G10 Robin 2 !
No interest of getting the FRN Robin if you have FRN Dragonfly. Too much weight on the FRN Robin.
Return to “byrd Knife General Discussion”
Users browsing this forum: No registered users and 1 guest
