Byrd Harrier 2 LWT (1st impressions/bladeplay)
samiam
Postby samiam » Fri Apr 09, 2021 7:26 pm
Replacing a Delica sent to the unknown.
Great thin slice-y option with a blade and handle length intermediate in length between Delica and Endura. For day-to-day use I appreciate the less swept point of the Delica/Endura profile much more than I expected, otherwise I would have replaced the Delica with a Stretch; but, $$ and I have a million other knives for animal processing (swept points).
However, the side-to-side play in the unlocked blade seemed excessive and I was unable to tighten the pivot enough to change this (doesn't even begin to stiffen opening, and the blade will still rattle with the lock-bar depressed. If this isn't a design feature, I suspect pivot washers from a thicker bladed model using the same lock-bar thickness were used. It seems like a 3mm lock-bar was used and the blade is, nominally, 2.8mm.
Is this normal? I notice it in use. If normal, are there suggestions on replacement washer thickness's to get?
Thanks all,
rangefinder
Re: Byrd Harrier 2 LWT (1st impressions/bladeplay)
Postby rangefinder » Sat Apr 10, 2021 4:10 pm
I have the G10 version of the Harrier 2, not the FRN/lightweight version. But with my knife, there is zero side-to-side movement with the blade in any position, from fully closed to fully open.
I also have a Byrd Cara Cara 2 rescue that has FRN handles. And it also has no side-to-side blade play.
So I'd say that this not normal. You should probably contact Spyderco customer service (or the dealer) to have it checked or exchanged.
z1r
Postby z1r » Sun Apr 11, 2021 1:57 pm
My first Spyderco was a Byrd Harrier 2 Lightweight. I initially thought it too big but have really come to appreciate the size and value the knife represents. Mine is but a month old but has no play in it.
bjz
Postby bjz » Mon May 03, 2021 9:53 pm
I purchased two of these last summer (just in case one had QC issues). They are both 100% solid with zero adjustments needed. I have a meadowlark 2 as well as a meadowlark rescue all in frn. Zero side to side play. (The rescue has developed vertical play from years of use and sitting wet for days on end in a life vest, but still no side to side).
Id say have it checked if you are worried, especially since you weren’t able to adjust it out.
Postby sal » Tue May 04, 2021 12:04 am
I Samiam,
Welcome to our forum. Blade play is most important in the open and locked position. We really don't push for very close tolerance in the unlocked position. If it's really a problem for you, you can send it to us and we'll make it right.
Hi Bjz,
Welcome to our forum and thanx for the comments.
Return to “byrd Knife General Discussion”
Users browsing this forum: No registered users and 5 guests
