Help with clip screws on Robin and Crossbill
zed4130
Post by zed4130 »
Hi guys, I recently purchased a Robin 1 and crossbill both SS , both had no clips, I’ve purchased 2 clips but I can’t work out what screws they use as I’ve tried a few from other knives and there either too big or to small, does anyone know what I need to order , thanks
Zed
zed4130
Re: Help with clip screws on Robin and Crossbill
Post by zed4130 »
So the screws from the crossbill are very tight in the robin ? Are the robins screws slightly smaller or different thread ?
toomanyquestions
Post by toomanyquestions »
I found the screws in my Meadowlark tight coming out; there appeared to be glue.
Interestingly, the deep carry clip I was using on my Para 3 (a Lynch clip I believe) would not accept the screws from the Meadowlark (I was planning to simply swap clips). A quick glance led me to believe the screws were fully interchangeable. Now I am left wondering: is the Lynch drilled to tighter tolerances, are the screws a different size, or was the glue the culprit?
At least the Meadowlark's clip seems to fit on the Para 3.
Giygas
Post by Giygas »
The Para 3 uses SAE 2-56 clip screws.
I have no personal experience with them, but I suspect the two Byrds being discussed here use either M2 or M2.3, and both could easily be mistaken for 2-56.
Currently testing: M398, D3, SLD-Magic
Favorites: 10V, s90v
Wishlist: S290, Vancron, S125V, K890
18 Spydies, 15 steels
13 Maxace, 9 steels
toomanyquestions
Giygas wrote:
Mon Jan 29, 2024 12:53 pm
Do you happen to know, are M2 / M2.3 common on Spyderco models (clips) from Asia? Or are these sizes just very similar in size to 2-56? I need to buy a few screws, and my knowledge is small.
Giygas
Post by Giygas »
Those are the only clip screw sizes I've ever personally seen used on non-Japanese, Asian made Spydercos.
13 Maxace, 9 steels
Ramonade
Post by Ramonade »
On chinese spydercos it's M2,M2.3, M2.5 and M3 (Tenacious).
I can check on the Robin and Hawkbill for you right now...
ETA :
- Robin G10 uses M2.3
- Byrd Hawkbill (sorry don't have any stainless byrds) uses M2.5.
