First Mule knife
First Mule knife
Well I bought my first spyderco Knife and it was a mule. I was impressed. I decide to try make handles for it shaping pins for it. It was going to till everything went out control. Sad to say my mule is snapped in half and I got 10 stitches.I do say Spyderco makes a quality knife a sharp one at that. Good quality. Not to expensive either. Cheap enough for me to be able afford one. Iam definitely going buy another Spyderco mule or some other Spyderco when I save up
Re: First Mule knife
Hi, Foner3:
Welcome to our forum. I'm sorry to hear about your issue and injury. I hope you heal up quickly.
Can you please tell us which Mule and how did it snap in half?
Kristi
Kristi
It was the rex t15 model the part snap in half was the front half where it piece wood really hard.I figured it being such hard steel. That it just snapped hitting the piece of wood.
- legOFwhat?
Sorry about your troubles Foner3. Welcome to the forum and hope you heal soon!
-Larry
MNOSD #0049
MNOSD #0049
Thanks for posting. Did you cover the edge with tape or something to make it more safe to work with?
Mule Team Army 001
MNOSD 008
MNOSD 008
- standy99
Chicks dig scars
We always tape mules whilst working on them.
But a high hardness steel is not going to be that tough for chopping wood. Keeps an edge longer but suffers in being brittle. The better the edge retention the lower the toughness.
Steel is a balancing act of edge retention, toughness and corrosion resistance.
I didn't think of taping until after everything went haywire. All I reamber was getting hit with it cut me open badly in the process the blad hit the handle material really hard and snapping in half. Lesson learn tape blade, Spyderco did really good on the sharpness though.
I often kill the edge on a sharpening stone then either use tape or paper around the whole blade. One time when I used tape it created a striped patina all over the blade so now I tend to use printing paper, surround the whole blade with it and then cover it of electrical tape.
I'm sorry about that misadventure, hope the injury wasn't too bad, even if that's quite the number of stitches !
MNOSD member 004* aka Mr. N5s
Darn, that is literally adding insult to injury. "Supersteel" doesn't mean you can do "super" things like hacking through Black Lightning's suit, or chopping into bank vault doors. What it means is that you can do normal stuff and the edge will last longer. At least that's my experience and interpretation.
Heal up and get yourself another blade to work with.
Rob
- standy99
Try using this type of tapeRamonade wrote: ↑Tue Sep 12, 2023 11:57 amI often kill the edge on a sharpening stone then either use tape or paper around the whole blade. One time when I used tape it created a striped patina all over the blade so now I tend to use printing paper, surround the whole blade with it and then cover it of electrical tape.
Looks like it’s sold in France by the label. Never had it mark a blade and it is fabric lined and rips off the roll nice and easy
Too bad the pictures do not display Do you happen to have the name of such tape ? I tries several different types with similar results, hence the paper
- standy99
Looks like catbox.moe is down
Try this
https://www.duckbrand.com/products/duck ... in-x-15-yd
