Will there ever be a Bushcrafty Pattern Mule ?
Dont get me wrong , I like my Mule ..
But !
A) The shape makes it hard to index the Mule in the hand for various tasks ( Curved grip )
B) The grip is a little cramped for my hand ( I had to stretch my Mule )
C) The Mule is not super comfortable for extended use ..
So the question begs .. Might there be a more traditional looking Mule in the future .
One that indexes better , feels better for extended cutting , something a little more BushCrafty maybe .
Just wondering .. ?
But !
Just wondering .. ?
Re: Will there ever be a Bushcrafty Pattern Mule ?
The Mule is pretty adaptable. You could definitely do some alterations yourself to make it more 'bushcrafty'. And that would definitely be in keeping with the spirit of the mule project.
Spyderco actually used to do exactly that with their “Bushcraft” model.
They sold it as the “Bushcraft Blank” (FB26SPEC) - https://www.spyderco.com/catalog/detail ... -Blank/471
- Nick
Hi Old4570,
Welcome to our forum.
We probably won't change the Mule much in the future. As mentioned, you can adjust the handle to suit your needs. By maintaining a consistent shape, it is more easily compared with other Mules.
Not that, please. I often cut or grind bits of my mule handles off, since the handle is extra real estate for me. (I wear L to XL gloves.) Much prefer to leave it as is, rather than to develop a mega-handled version with handlelephantitis. Adding more handle is easily done with larger scales, if you need it.
- standy99
Basically the mule is the mule…
Nearly 40 steels and still the same shape size and dimensions. (Roughly)
Spyderco needs a good bushcraft knife but your better off starting a thread in the open forum for a bushcraft fixed blade then hoping the mule will change
I don't want the Mule to change ,,
But if there was another Mule .. Something a little more generic .. ( 2nd Type of Mule or maybe don't call it a Mule )
Or bring back the bushcraft blade ?
I don't want to change the Mule , just maybe add to it . ( Another Mule - Mule 2.0 )
From a marketing perspective , the more you sell , the better ?
A mule by concept is a point of reference, making "another mule" would denature the principle of a Mule IMHO.
Seems like a Bushcraft fixed blade that could be available in different steels is something everyone would like.
The Enuff line seems almost perfect, maybe Enuff Wood ?
MNOSD member 004* aka Mr. N5s
I haven't recovered from the controversy around the change in blade shape on the SPY27 run... can't imagine introducing such a different blade shape to the Mule line and the ensuing trauma it would cause
I think the OP is suggesting a bushcrafty line of Spyderco blanks, rather than a modification to "the mule." And I further suspect that Spyderco has no interest in making any other blanks, other than for the purposes of testing, via the already established mule. I think Spyderco would be much more likely to simply produce complete models of bushcrafty knives, than blanks.
If that's true, and if the OP wants to make his own, then I'd recommend he look at some of the knife component suppliers...there are bushcrafty blanks out there, some of good steel...they're just not Spyderco made.
It should be as simple as not naming it “Mule Team.”
They’ve done it in the past with the FB26 Bushcraft Blank and FB27 Woodcraft.
• Mule Team
• FB26SPEC Bushcraft Blank
• FB27 Woodcraft
https://www.flickr.com/photos/50628075@ ... otostream/
The Spyderco FB27 Woodcraft was an exclusive for Woodcraft.com. Apparently, Woodcraft called the knife a Mule Team in error, as it was not actually part of the Mule Team. The knife was also not S90V as they stated, but rather S30V.
Photo source - viewtopic.php?p=879305#p879305
Given the current popularity that the Native series and Mule Team both enjoy, I’d venture to guess a new run of a knife like the FB27 Woodcraft would see similar fanfare because it is basically Native 5 fixed blade blank. The handle looks nearly indentical.
- Nick
Well, I would be in for one of each of those blanks please and thank you.
I would also like the parallel universe where there are 2 new Golden production facilities running full tilt sending us the platforms of our dreams.
And, here we are on a forum where a user can garner enough interest, fill enough pages keeping the thread alive, and eventually, see a given knife get another run. Spyderco and the forum are amazing.
