Fictive Chaparral XL: Follow up: How would you design it specifically?
(EDIT: Reading my post again, I realized that maybe there is not a whole lot to discuss here, since the topic is very narrowly defined. I´ll post it anyway... )
Some weeks ago I started a poll, asking who´d like to see a longer version of the Chaparral while keeping it´s overall thinness and especially the thin blade stock. Quite a few people showed their interest (viewtopic.php?f=2&t=82492)
I´ve been contemplating what I personally would like a Chaparral XL to look like exactly, if I could design it. I´ll list some thoughts below, maybe some of you find it interesting to discuss the topic.
So: The guideline here is: It should be a Chaparral in a longer version, not any other knife; it should keep it´s key feature, the overall thinness, especially the slicey, thin blade. And I mainly think about a FRN version
Length: I´d like to see the proportions between a Chaparral and a Chap XL to be somewhat like the proportions between Delica and Endura:
That would mean: Closed length Chaparral: 91 mm; Chap XL 107 mm; Blade length Chap: 71mm; Chap XL: 85 mm (the difference between Delica and Endura blade is bigger, cause the blade of the Delica is not as long as it could be concerning space in the handle)
Width: I´d keep the XL as narrow as the regular Chap, both in handle and blade
Blade stock; I´d keep it 2mm (to create a longer slicer is the whole point), at most 2,4 mm (so still thinner as a Delica)
handle thickness: I´d keep the handle of the Chap XL as thin as the handle of the regular Chap. Things you do with such a thin knife do not require a fat "hard use handle"
Choil: Keep the size of the choil exactly as it is, do NOT make it bigger and do NOT extend it further into the blade, so the blade length you gain in a Chap XL is ALL cutting edge
Color: I´d give it kind of a "classy" color again - so maybe grey like the regular Chap, or a very dark, noble red...
Re: Fictive Chaparral XL: Follow up: How would you design it specifically?
Have you tried mocking it up with cardboard?
Not yet, but good idea!!
- steelcity16
I'd take the current chap lw, make it ever so slightly longer with the same thickness, and make it a salt version with DLC coated LC200N blade, black FRN, and coated stainless/titanium hardware. Man, that would be a sweet little knife!
- bearfacedkiller
The Sage is basically a scaled up Chap. I would love to see a Sage with 2mm blade stock.
The Sage 4 shared the same lock including the AWESOME internal stop pin but it was a chunky knife. If it had been as thin as the Chap I would carry mine much, much more.
How much longer would you like it? I think around 20 % more actual edge would be great...steelcity16 wrote: ↑Mon Jan 28, 2019 1:06 pmI'd take the current chap lw, make it ever so slightly longer with the same thickness, and make it a salt version with DLC coated LC200N blade, black FRN, and coated stainless/titanium hardware. Man, that would be a sweet little knife!
I'd modify it slightly so it looked more like this.
Bladestock W A Y too thick...
And XHP.bearfacedkiller wrote: ↑Mon Jan 28, 2019 1:10 pmThe Sage is basically a scaled up Chap. I would love to see a Sage with 2mm blade stock.
Now more serious and detailled reply: Compared to the Para 3 lw, for me the Chaparral is NOT about light weight. Though it is quite light, with it's steel liners and steel backspacer it actually feels rather heavy in a positive way (solid) for it's size. That I would also like to see in a Chap XL. It's more about beeing very thin, and therefore a great carry and an amazing slicer.
I guess for over 90 % of regular knife tasks 2 mm stock is enough and even better than 3 or 3.7....
So I think for people who actually do knife stuff with their blades and not crazy hard use tasks, a slicer like the Chap but longer would be great.
Right, a sage backlock but in FRN, thin bladestock and thin handle as well as a little narrower overall (as wide as the Chap but longer) is pretty close to what I imagine a Chap XL to be.bearfacedkiller wrote: ↑Mon Jan 28, 2019 1:10 pmThe Sage is basically a scaled up Chap. I would love to see a Sage with 2mm blade stock.
