Show off your Natives.
- przemekspce
Re: Show off your Natives.
Instagram: przemekspce
- przemekspce
- Makunochimaster
Native 5 cpm-s110v G10. Native 5 cpm-s110v frn.
Lil' Native MB cpm-s30v. Dragonfly 2 zdp-189.
Delica 4 cts-204p limited. Cricket Nishijin blk vg10.
Urban n690co. Persistence s35vn lightweight.
- Makunochimaster
Spyderco's company motto
^^^GASP^^^
Native 5 G10 S35VN
Native 5 fluted CF S90V
Native 5 LW Maxamet
Native 5 LW LC200N
Native 5 LW S110V
MNOSD member 004* aka Mr. N5s
I think part of what turns me off about the Native is actually a lighting artifact. The bevel on the spine often disappears in pictures, making the knife look like it has an abrupt grind through what should be a graceful curve. The dark blue native above shows the effect and the cure so to say; the spine bevel appears dark such that the “bright” part of the blade shows an unappealing grind; but when the light shows the bevel at the same brightness, it looks right/better etc. Kobold’s picture lights up the whole spine.
I agree with you on that, I've always found out to like it more in hand than in pictures. The swedge is way more defined IRL, while in picture the different angle of reflection can make it disappear or just look less defined. Only Native 5 where the swedge is less defined is the Maxamet, because the deep stonewash smoothes every lines !Woodpuppy wrote: ↑Tue Nov 23, 2021 7:27 amI think part of what turns me off about the Native is actually a lighting artifact. The bevel on the spine often disappears in pictures, making the knife look like it has an abrupt grind through what should be a graceful curve. The dark blue native above shows the effect and the cure so to say; the spine bevel appears dark such that the “bright” part of the blade shows an unappealing grind; but when the light shows the bevel at the same brightness, it looks right/better etc. Kobold’s picture lights up the whole spine.
I found this to be true of the Shaman too. I got the Z-wear sprint because in my mind it was THE version to have, and after feeling and using it I appreciate it much more. It has caused me to think about a Native.
After hating it for months, now I can't live without it.
- przemekspce
- Makunochimaster
Maxamet Native 5.
MNOSD member #0035
MNOSD member #0035
- Manixguy@1994
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
