Read this everyone:
https://www.forbes.com/sites/davidbress ... db47e5570a
https://www.mdpi.com/2075-163X/8/12/601
It is an aluminum-zirconium-titanium-oxide material with some other elements mixed in. A sapphire like thing. Some claim it is harder than diamond, others that it is just denser.
Make knives from this! Carmeltazite
- SpyderEdgeForever
- demoncase
Re: Make knives from this! Carmeltazite
Tells you why no-one will be making knives from this- it's rare (so massively expensive), only found in small sizes (so not going to be blade stock) and actually isn't harder than sapphire."The theoretical density (calculated from the crystal structure) is 4.12 g/cm3, higher than a diamond with 3.52 g/cm3. However, this doesn't translate, as erroneously reported by some media, in a higher hardness"
"The largest stone discovered so far is 0.25 oz"
Theoretical density is always a bad sign- that tells you there isn't a big enough non-porous lump to drop it into water to do a standard gravimetric density test
Does look pretty though. :)
